I had a message pop up showing "Check Coolant Level", I pulled over and checked the coolant, then again later in the day and the coolant was just fine.
Has this happened to anyone? What was the cause? Is there some sensor that I should check?
Thanks a lot.
Vyn
Really sounds like your coolant sensor may need replacement or it might even be your water pump possibly on the outs.
This happened to me on the way back from Palm Springs.
Checked the coolant level and all was fine. Took the car to the stealership and they said my computer had no record of the error.... Only happened that one time and hasn't happend since then. That was over 8 months ago. I had forgotten all about it until I read your post.
