I beleaveyou cajn heat thesprings to achieve both. You need to heat only the middle of the springs. That way you maintain spring memory at the top and bottom. It seems that if you could come up with a heat sink to protect the rest of the spring youd besafer. Remember a little at a time until the desired ride hieght is achieved.ride height is secondary to gaining stability in turns. that said I would prefer not to raise the car if possible.
The very best way is a set of shorter springs 2nd best way take spring out and match the end as close as possible when you cut it. I have cut many coil springs normally I only take a 1/2 to 1 wrap off....on the vette I would'nt cut too much off of it because THEN you'll take the risk of bottoming the front-end out on driveways, slopes ect. last thing I'd do EVER is heat them and let them sag.#1 you can't [I doubt] heat both springs at the same rate/heat and thats all blind quess work, and #2 you WILL cause a spring rate problem. Cut a 1/2 coil and try that if you can't afford shorter springs using a cut-off wheel w/die grinder you won't heat/sink the spring that way.IMHOI beleaveyou cajn heat thesprings to achieve both. You need to heat only the middle of the springs. That way you maintain spring memory at the top and bottom. It seems that if you could come up with a heat sink to protect the rest of the spring youd besafer. Remember a little at a time until the desired ride hieght is achieved.
heating them up is a lazy, backyard when I was a teenager way of doing it. Surely not a Vette.The very best way is a set of shorter springs 2nd best way take spring out and match the end as close as possible when you cut it. I have cut many coil springs normally I only take a 1/2 to 1 wrap off....on the vette I would'nt cut too much off of it because THEN you'll take the risk of bottoming the front-end out on driveways, slopes ect. last thing I'd do EVER is heat them and let them sag.#1 you can't [I doubt] heat both springs at the same rate/heat and thats all blind quess work, and #2 you WILL cause a spring rate problem. Cut a 1/2 coil and try that if you can't afford shorter springs using a cut-off wheel w/die grinder you won't heat/sink the spring that way.IMHO
there is no problem heating a spring , they don't need temper and so what if they break. l.o.l. cutting is the better way unless you have a set custom built .:cheers:heating them up is a lazy, backyard when I was a teenager way of doing it. Surely not a Vette.
