lights wont go off unless i pull fuse. service manual says disconnect delay timer thats behind the right side of i/p multi-use center. How the hell do i get to it. I pulled the info center out but cant locate or get at timer.
any help or suggestions on a easier check to see why lights stay on is appreciated.
Thanks
Robbie
Is it the 87 or 94? I know on the 94 you can access them by removing the hush cover (carpet) on the under side of the pass side dash.....
Sorry it's the 87 I'm wondering if I have to take the bread box off. What a bitch to locate just to check it
Discussion Starter #5
Did that already. I put the new radio in on sat and all was working till I pulled in garage last night cause of snow were getting. I'm guessing I hit the connector and it cme lose. If only I can see the bastard!!!!!
Had the same problem, check the door switches. My drivers door switch was worn down so when the door was closed it did not open the switch. I fixed it by placing some rubber shims behind the switch flange . Worked for me. (Always look for something simple first.)
Good luck
