1 - 2 of 2 Posts
So my daughter slammed the passenger door the other day and now all the interior lights are stuck on all the time.
I tried pressing on the door ajar switch thinking this might be it since I did recently put new door seals on. No go.
I pulled the courtesy timer and they still stay on.
I disconnected the light switch: still on.
The only way to turn them off is to disconnect the fuse. So I guess I'm down to a short somewhere?
Does anyone know where the white ground wire for the interior lights grounds out at before I disassemble the entire dash? FSM isn't much help here.
Hey Robs
I had similar, found the door switch was worn so it was a bit shorter, thus when the door closed it did not quite turn off the lughts.You have new seals, they may be holding the door just a bit out. I shimmed the switches with a bit odf reubber behind the mounting screws. Works fine now.
Good luck
1 - 2 of 2 Posts
