Smokin Vendor
Corvette Performance Spark Plug Wires for 1997-2013 C5 & C6
Corvette Shielded Spark Plug Wires
If you are tired of burnt spark plug wires due to your Corvette’s Headers? These Hi-Performance C5 & C6 Corvette Spark Plug Wires are built to Zip Corvette’s standards, which means they are built specifically for Corvettes and with the required heat protection for long tube headers.
Zip’s Corvette spark plug wire sets begin with a heat shielded Magnacor wire. Magnecor’s exclusive 2.5mm high capacity Metallic Inductance EMI Suppressed conductor consists of a stainless steel wire precisely wound at 200 turns per inch over a ferromagnetic core. The insulating jacket is made entirely of Magnecor’s exclusive TC-1500-HS high strength aerospace grade silicone rubber, and its single layer construction will prolong the jacket’s insulating ability by conducting extreme heat away from hot-spots that occur near over-the-limit heat sources.
The protection provided from the heat shield guarantees that this will be the last set of spark plug wires you will ever have to replace from header burn. The KV85 8.5mm jacket has a service heat resistance of 600 degrees F (320 degrees C) and up to 1,000 degrees F (540 degrees C) for a short burst of 3 minutes. The R-100 10mm jacket has a service heat resistance of 700 degrees F (380 degrees C) and up to 1,200 degrees F (650 degrees C) for a short burst of 3 minutes. Even if limits are exceeded, the silicone rubber will retain its insulating ability until wires are removed from engine.
Magnecor wires are primarily designed and constructed to be used in applications where it is essential to prevent the possibility of ignition wires compromising engine performance. Modern race engines, modified street engines and stock street engines which rely on electronic devices to control the function of either or both the Corvette ignition and fuel systems are prone to interference from all other spiral conductor ignition wires sold through performance parts outlets, none of which can provide proper suppression for EMI, particularly if a high-output ignition system is used.
Zip Corvette always recommends use of these performance spark plug wires on any stock or modified late model Corvette engine that is electronically managed however most other modified or street engines can also use our performance spark plug wires to improve ignition performance. Fits all 1997-2013 Corvettes with or without headers.
Both the red and blue sets of these Shielded Corvette Spark Plug Wires fit all C5 and C6 Corvettes. These wires are also a great ignition upgrade for your 2009-2013 C6 ZR1 Corvette.
