Give the rear view of your 1956 – 1957 Corvette new life by installing LED tail lights *- you’ll also increase safety and efficiency as you drive. LED lights are brighter, appear quicker, burn cooler and last longer than your C1 Corvette’s factory tail light bulbs.
Each 1956-1957 Corvette LED Tail Light Lens & Bulb Assembly Kit includes a new reproduction tail light lens, LED light bulb assembly and wiring harness pigtail that will connect directly into your Corvette rear wiring harness. There are no modifications required for this installation and you can return your Corvette back to its factory, original appearance at any time. *Sold in pairs.
While you’re equipping your Corvette with LED lights, you may also want to consider a Corvette LED Flasher Assembly. LED bulbs draw much less current than factory style bulbs, so your turn signal indicators will flash faster due to a blown bulb warning. These replacement flashers will provide the resistance needed to make the LED turn signals flash correctly. Fully electronic, no load replacement flashers are made for LED technology and will drive your LED indicator bulbs safely. Ground Black wire to a body or dash ground.
Purchase online at Zip*Corvette Parts
