Ignitor Electronic Ignition Conversion Kit components fit inside the distributor cap for a truly stealth install.
The Ignitor Conversion Kit replaces your stock points and condenser with a solid state electronic module, using a stock or high output points type coil. You’ll enjoy quick starts, better fuel economy, longer plug life and more horsepower.
The Ignitor II Conversion Kit senses current levels in the coil and adjusts the dwell to maintain peak energy throughout the entire RPM range. Dwell time is increased or decreased with changing engine RPM and operating conditions. This provides more energy at high RPM, reducing misfires while improving engine performance.
The Ignitor III Electronic Ignition delivers “box ignition” performance – without the box! This kit delivers 5 times more spark energy than points, plus a user-set rev limiter.
All kits are compatible with stock coil. For more juice, add a Corvette Flame Thrower Ignition Coil and matching spark plug wires. The epoxy filled coil generates 40,000 volts of pure power and the silicone-jacketed wire sets feature rubber inner insulation for superior heat resistance. No cutting, splicing or scrimping needed with these wires.
What are you waiting for? Set your C1, C2 or C3 Corvette ignition on fire!
- 1957-1974 1×4 Single Point Ignitor Conversion Kit
- 1957-1974 1×4 Ignitor II Conversion Kit
- 1957-1974 1×4 Ignitor III Conversion Kit
- 1956-1974 Flame Thrower Ignition Coil
- 1957-1974 Flame Thrower 7mm Spark Plug Wires
- 1965-1974 Flame Thrower 8mm Spark Plug Wires
