1 - 4 of 4 Posts
I need a little help on adjusting my top. What seemed very simple turned into a math problem :)
I have the following probems:
a. excessive wind noise
b. one of the windows catches on the top
c. needed a quick rinse and went through one of those touchless car washes and water was shooting in both windows along the top and rear corners
So I think I need to adjust the top and do a window tip. Your thoughts?
The problem comes in when adjusting #5 Bow. Which way to you turn to get the connecting bolt? Where is the 13mm bolt when you first start adjusting? I can get one end all the way down and other end comes out. Turn in one direction and it seems to be doing opposite things on the two rods that it is connecting.
Attempting to adjust so that it resembles the picture that is provided and only a 2mm separation. Right now, I'm completely opposite of the picture. I'm sure you've seen the pics on various forums discussing top adjusment.
Help me out smart this connection because I'm obviously not smarter than a fifth grader :)
Thanks - can you respond to [email protected]
Ron
VETSTYL
broken link
[quote ---> c5forum.com/cgi-bin/ultimatebb.cgi/topic/1/2213.html <---- /quote]
this link raises a database error...
1 - 4 of 4 Posts
