I have a '99 that has someting wacky going on. Every once in a while the car shuts off and I have on the message center "Reduced Engine power" followed by "Low Fuel" The first time this happened as I was calling the tow truck I decided to try starting once more, about 15 minutes after I went dead. The car started and went home about 35 miles. Since then it has happened and I replaced the fuel pump micro relay, it was very warm to the touch. I've gone several trips and months with out a problem and now it started doing it again. If I remove the relay and re-insert it again the car starts. But the relay is warm to the touch. All other relays in the box are cool to the touch. And even one time I had the traction control go off at the same time. Does anyone have any suggestions here?
