I noticed there is fore and aft movement at the ourboard end of my clutch linkage cross-shaft on my '72 4 speed. The nut on the ball shaft is not tight but the lock washer prevents the nut from turning. I guess the ball shaft turned over time in the nut. What is the best way to re-tighten or replace the ball shaft and nut? I have found diagrams on this structure but no instructions on how to do it properly.
I just removed mine to pull the motor and will look at it later today to see if I can comment.
The nut SHOULD tighten. Mine does and my cross shaft is tight; no foreword/aft movement.
There is some play at the nut (now that it is out) as it is on a ball at the end of the shaft but it was tight when installed. I can't see anything else x to say that maybe where the ball at the nut seats is worn on yours? You may need to replace the cross shaft assembly.
Glad to have you here! :burnout:
