1 - 9 of 9 Posts
what are your heads, your cam is a little bigger than stock, but if your running a TPI and stock heads, anything bigger is not going to help much
Installed in my engine.
230/230 .50
480/480 @ 109 Separation.
How is this cam?
That cam will improve your power up until about 4000 rpm but then your TPI will prevent it from producing much more. Like the older CrossFire Injection, the TPI produced good torque up to about 4000 then abruptly quit breathing. To take advantage of that cam's breathing potential you'll need to change your cylinder heads.
1 - 9 of 9 Posts
