Im looking to buy a set of C6 wheels (rims and tires) for my C5...I know the wheels are 1 inch bigger from the front and rear on the C5's. Will these wheels work ok on my c5?
these are just reproduction wheels with c5 offset differnt sizes i have the c6z06 reproduction hrome with 295 tires didnt rub till i lowered it and now it rubs so slightly you cant tell unless you take the wheel off and look at the plastic in the fender wheel. and just rubs in the back figure its from taking corners at the "speed limit" lmao
If the C6 wheels you are buying are for the C6 you will need a rear spacer to bring the rim out closer to the quater panel.
Please elaborate on this??If the rims are going to 18"x8.5 front and 19x10 rear w/265x35x18 frnt tire and 285x35x19 rear tires,......A spacer??For example??Please help?................:burnout: :cheers:
