:woowoo:I sold the '68, and this is a list of the left overs. PayPal ok, picrures available. Prices are retail, taking best offers on all or anything! Buyer pays postage, etc.
CORVETTE PARTS - ITEM DESCRIPTION SUPPLIER ITEM NUMBER EACH/OFFER SUPPLIER - USED DRIVER QUALITY
CROSSED NOSE FLAGS - 68-72 - $5.00 DRIVER - USED
DOOR HANDLES - OUTSIDE 1968 ONLY $25.00 DRIVER - USED
SILL PLATES & SOME SCREWS - 68-77 $25.00 DRIVER - USED
CENTER SHIFT PLATE - 350/350 AUTO - L/R & CTR OPTIC $10.00 USED - ROUGH
V/CVR ENGINE CODE "HE" 66-68 262750 $1.99 Corvette Central
300HP 4-SPD TRANS EMISSION DECAL UNDER HOOD (2) 68 263306 $5.15 Corvette Central
LEFT MIRROR - NO DATE - 68-74 $40.00 DRIVER - USED
TAIL LIGHTS - LENS - 68-69 $20.00 2 GOOD - I CRACKED (FREE W/ OTHERS)
PARKING LIGHTS LENS - 68-69 CLEAR $10.00 1 GOOD - 1 CRACKED (FREE WITH OTHER)
FRONT LOWER MOLDING GRILL 68-69 L&R (BOTH) $80.00 DRIVER - USED - rechrome them.
EASTWOOD SILVER CADIUM PAINT $8.95 NA
RALLY WHEEL PAINT - ARGENT SILVER 642176 $7.95 Corvette Central
SHERWIN WILLIAMS ACRYLIC SEMI-GLOSS ENAMEL BLACK $5.95 NA
CTR CONSOLE PARK BRAKE SLIDE 68-76 233106 $5.50 Corvette Central
REAR SPINDLE BEARING DUST DEFLECTOR (2) 68-82 SU-360 $9.99 ZIP CORVETTE
OIL GAUGE LINE KIT 68-73 SB/68 427 33626 $9.99 Corvette America
OIL GAUGE LINE FITTING 68-73 SB 33627 $6.99 Corvette America
OIL LINE GROMET FIRE WALL 68-74 33632 $4.99 Corvette America
OIL PRESSURE LINE FITTING 68-73 40892 $15.99 Corvette America
LOWER RAD. HOSE - 68-72 SMALL BLK M2286 $31.50 NEW - GM STAMPED - ZIP
DOOR HANDLE GASKET 68 A-554.9 $3.99 ECKLERS
MIRROR MOUNTING KIT - LH 68-75 2015K $9.00 PARAGON
DOOR PANEL FASTNERS (10) 68-77 #2347 $2.99 CORVETTE AMERICA
DOOR PANEL MOUNTING KIT 68-77 43227 $5.00 CORVETTE AMERICA
DOOR INSIDE HANDLE - X FLAGS LOGO 68-77 483386 $4.50 ONLY ONE - NEW
IGNITION SHIELD TOP COVER 68-70 270080 $29.00 Corvette Central
IGNITION SHIELD LEFT VERTICAL COVER 68-77 270093 $49.95 Corvette Central
IGNITION SHIELD RIGHT VERTICAL COVER 68-77 270094 $49.95 Corvette Central
WING NUT - IGNITION/SPARK PLUG SHIELDSE 15 TOTAL) 68-77 $1.00 NA
REAR WHEEL SPINDLE SPACER & SHIM SET 63 - 82 SU-306 $23.98 ZIP CORVETTE
GAS PEDAL / CHROME TRIM 68-72 29468 & 29469 $16.98 CORVETTE CENTRAL
WIPER MOTOR FIREWALL SEAL 63-82 185111OR 185285 $2.00 KEEN PARTS
WHEEL BEARING KIT - 63-82 (2) M-258 OR M3899 $38.95 ZIP CORVETTE
REAR SPINDLE BEARING DUST SHIELDBEARING SHIELD 63-82(2) SU-359 $6.95 ZIP CORVETTE
OIL FILTERS (PF-25) AC/DELCO REPODUCTION BLUE 68-77(2) 303079 $6.95 Corvette Central
PF-25 WHITE BOX - BLUE FILTER OE TYPE 68-77 PF-25 $9.95 NA/ NEW IN BOX
REDLINE ENGINE COOLANT - 12 OZ 241041 $9.85 Corvette Central
FUEL FILTER GF-432 W/ BRACKET(?) 68-69 ONLY AC NEW $45.00 NEW IN BOX
BATTERY CAPS - SET OF 6 DELCO (DELCO EYE) (2) $6.00 NEW
ASH TRAY - RUSTED BOTTOM $2.00 DRIVER - USED
"T" EXPANSION TANK - 63- EARLY 68 M-207 $5.00 ZIP PARTS
VISOR ROD - WITH SCREWS(2) 1968 $5.00 DRIVER - USED
WASHER HOSE - PART OF SET $5.00 NEW
HORN RING CONTACT SPACER - TELESCOPE WHEEL 68-82 562120 $5.00 68-82 NEW
PLUG WIRE SET - AC/DELCO 57-74 SMALL BLK M-198 $44.95 NEW
FRONT LICENSE PLATEMOUNT -68-72 $10.00 DRIVER - USED
WIPER SWITCH - NOT 100% SURE IT WORKS 68-? FREE ASK!
PENNSYLVANIA LICENSE PLATE 1968 $25.00 USED - MINT
AMMOR R SMITH - YORK PA DEALER FRONT LIC PLATE $10.00 LIKE NEW
BOOKS - LITERATURE
WHAT YOU SHOULD KNOW ABOUT ---EMMISSIONS GM $5.00 NEW
BROWN FOLDER FOR MAINT RECORDS GM REPRINT $5.00 NEW
1968 CORVETTE ADV - OLD HOT ROD MAG. 1968 - ? $10.00 GREAT COND
ACCESSORY PRICE LIST GM REPRINT $5.00 LIKE NEW
PENNSYLVANIA STATE INSP STICKER - 1968 NEW - ORIGIONAL $50.00 NEVER USED FROM 1968
REPO OF ABOVE NEW $3.00 NEW REPO
POST CARD - WHITE 68 CORVETTE - DEALER MAILING GM REPRINT $5.00 LIKE NEW
TRADING CARDS - 1968 (4) 427 BB - COUPE/ROADSTER $5.00 SET OF 2 & 2
CORVETTE PATCHES - ROUND CLOTH $3.00 (2) NEW
HAT PINS - ALL ROADS LEAD TO NASHVILLE - 6/2003 $5.00 (2) NEW
CHEVROLET DEALER PARTS CATALOG - 1953-1981 Corvette NEW $100.00 MINT
1968 CORVETTE ADV - OLD HOT ROD MAG. (1968) $10.00 LIKE NEW - YELLOW ROADSTER
HEADLAMPS - 3-T 1 LO/1 HI - USED $10.00 EACH
HEADLAMPS - SET REPO 68-71(?) SB38-71S $149.95 LETRIC LIMITED
BATTERY CAPS - 1968-69 ONLY (3 IN ONE) WITH HOSES USED $75.00 USED - GREAT COND.
ROOF GROMET GUIDE BUSHINGS - A271.5 $2.50 ECKLERS
NO IDEA!! SMALL SQUARE THIN PLASTIC A911.0 MAKE OFFER GM# 3918560
BULBS - SMALL
GE 1157 CLEAR ONE $1.00
GE 1157 AMBER 1 OLD STYLE ONE NEW STYLE 2 TOTAL $1.00 EACH
GE 1156 CLEAR 4 TOTAL $1.00 EACH
GE 1895 CLEAR 3 TOTAL $1.00 EACH
FUSES
ACG 1 1/2 - (3AG) 2 TOTAL $1.00 BUSS W/ CASE
SFE 20 5 TOTAL $1.00 BUSS W/ CASE
AGA 5 6 TOTAL $1.00 NAPA IN CASE
FUSE EXTRACTOR 1 FREE BUY ALL FUSES!
$1,214.33
REASONABLE OFFERS ACCEPTED!!!! Will tke $600. for everything
BOOKS - LITERATURE
BULBS - SMALL
FUSES
$1,214.33
