Smokin Vendor
One simple way to keep your Corvette running “like new” for years is to use BG Products to help maintain your Corvette’s fuel system, power steering, engine oil, transmission and more. BG Products have been around since the early 1970s and continue to help Corvettes run more efficiently every day. Don’t abuse your Corvette any longer, start using BG Products today.
BG 44K Power Enhancer safely, rapidly and thoroughly removes engine deposits in combustion chambers, intake manifolds, ports and on valves. It restores flow in fuel injectors and cleans the Corvette’s entire fuel system. BG 44K Power Enhancer improves fuel economy and reduces exhaust emissions. It restores that “like new” drivability to an engine’s performance and keeps it running better, longer and more efficiently. Just add one bottle to your Corvette’s fuel tank at fill up and your Corvette will be good to go. After cleaning up with BG 44K Power Enhancer, regular use of BG Supercharger II, in gasoline engines or BG Diesel Fuel Conditioner with DPL, in diesel engines will prevent deposits from forming in the fuel system and upper engine for maximum drivability and fuel economy.
BG ATC Plus enhances properties of both new and used automatic transmission fluid. It improves fluid oxidation stability, thereby prolonging fluid life and the life of your Corvette’s transmission. It prevents leaks by conditioning hardened seals- keeping them soft and pliable. BG ATC Plus helps control transmission shudder, retards formation of sludge and varnish deposits and prevents foaming.
BG MOA Oil Additive prevents oxidation and thickening of engine oil under even the most severe stop-and-go, high temperature driving conditions. It fortifies all qualities of engine oil to provide superior long-lasting engine protection and helps maintain optimum engine performance. BG MOA keeps piston ring belts, hydraulic lifters and other engine components clean to help extend engine life and reduce costs of operation. It is compatible with both synthetic and petroleum-base oils. The Thin Film Oxidation Uptake Test (TFOUT), ASTM Test Method D4742, proves BG MOA’s remarkable resistance to oxidation by more than 200% longer than six major brands of SL quality oil. At the conclusion of the API Sequence IIIF Engine Test, a major brand, high-quality reference oil barely passed the 80-hour test with a viscosity increase of 255 percent. At 80 hours, another brand of oil fortified with BG MOA had a viscosity increase of only 57 percent. At the conclusion of the triple-length, 240-hour test, it was still well within the viscosity limits with an increase of only 198 percent.
BG 109 Compression Performance Restoration is a revolutionary formula with proven “ring-clean” technology. It is a quick and effective blend of cleaners that will soften, emulsify and dissolve those hard to remove fuel gums that clog rings and will usually do it in 15 minutes or less. Compression will increase with removal of these deposits. BG 109 also lowers tailpipe emissions, eliminates oil consumption associated with buildup and improves overall power and economy. BG 109 is safe for use in diesel and rotary engines.
BG Supercharge II, when used regularly in each tankful of gasoline will prevent deposit formation throughout your Corvette’s fuel system. BG Supercharge II improves engine performance and gas mileage, lowers exhaust emissions and substantially reduces drivability problems caused by deposit build-up. It prevents rust and corrosion and provides long-term storage stability. BG Supercharge II is non-injurious to all types of materials used in fuel systems and is also catalytic converter and oxygen sensor safe.
BG Power Steering Conditioner is specially designed to help prevent power steering unit leaks, provide smooth operation and eliminate squealing. It fortifies any power steering fluid, cleans and smooths internal springs and valves to help eliminate sticking, and reduces parts wear. BG Power Steering Conditioner also conditions and helps protect seals against drying and shrinking to prevent fluid leakage.
BG Synchro Shift II is a gear lubricant specially formulated for manual transmissions. It does not sacrifice any performance as does engine oil, ATF or conventional gear oil. It provides required thermal stability, low-temperature fluidity, hot rattle suppression, noise dampening at operating temperature, outstanding extreme pressure characteristics, shear stability, smoother shifting characteristics, wear reduction (synchronizer, gears, bearings, shift fork), seal compatibility, and reduced maintenance costs. BG Synchro Shift can be and is recommended to be used instead of the ATF fluid in C5 or C6 Corvette manual transmissions.
BG Ultra Guard is the first “true” multi-purpose gear oil available in the automotive market. It is a synthetic (polyalphaolefin) gear oil blended to SAE 75W-90 viscosity and can be used in all car and truck axle applications calling for a GL-5 gear oil. It can also be used in all truck standard transmissions and automotive manual transmissions, transaxles and transfer cases calling for GL-4 gear oil, engine oil or ATF, as long as viscometric requirements are satisfied. BG Ultra Guard provides thermal stability, optimum drive line efficiency, quieter operation, protection against wear, pitting and corrosion, seal compatibility and improved seal performance, improved fuel efficiency, reduced maintenance, long drain life, extended component life, and application versatility. BG Ultra Guard is covered by the BG Best Guarantee Program and is not to be used in C5 or C6 Corvette manual or automatic transmissions.
BG Ultra Guard II is the first “true” multi-purpose gear oil available in the automotive market. It is a synthetic (polyalphaolefin) gear oil blended to SAE 75W-140 viscosity. This is the H.D. version of the Ultra Guard 75W/90 but for more severe applications such as race differentials. BG Ultra Guard II provides thermal stability, optimum drive line efficiency, quieter operation, protection against wear, pitting and corrosion, seal compatibility and improved seal performance, improved fuel efficiency, reduced maintenance, long drain life, extended component life, and application versatility. BG Ultra Guard II is covered by the BG Best Guarantee Program and is not for use in C5 or C6 Corvette manual or automatic transmissions.
BG LSII Limited Slip Additive is designed to prevent chatter in plate and clutch type limited slip Corvette differentials. BG LSII may be used with any GL-5 gear lubricant in limited slip applications. The ingredients in BG LSII allow for a smooth and quiet operation of gears in the differential and fortify the additives in the gear lubricant.
BG Frigi-Fresh is formulated to quickly and effectively eliminate foul, musty odors from automobile air conditioning systems. It kills mold, mildew and other odor-producing organisms that grow in the evaporator core and housing. Powerful deodorizers in BG Frigi-Fresh keep the automobile interior smelling fresh and clean.
BG White Lithium Grease is a lithium-based lubricant in a convenient aerosol container that allows for easy application on hard-to-reach areas. It protects against water and oxidation problems and is an outstanding automotive body parts lubricant for door hinges, locks, seat tracks, and manual window regulators.
BG Silicone Spray Lubricant penetrates surface pores and remains fluid without thickening or evaporating through aging. It prevents almost anything from sticking and is extremely long lasting with a wide temperature range.
