1 - 2 of 2 Posts
Hi everybody,
I wonder which is the best cylinder heads to a L82 original engine for Corvette 1979 owners ? I found these choice, each one has a different Maximum Valve Lift.
What's your advice for choice the right one ? :
TFS
Trick Flow Specialties TFS-30210006 Trick Flow® DHC™ 175 Cylinder Heads for Small Block Chevrolet | Summit Racing : Intake runner 175cc, combustion chamber 60cc, maximum Valve Lift 0.540 in
Trick Flow Specialties TFS-30210007 Trick Flow® DHC™ 175 Cylinder Heads for Small Block Chevrolet | Summit Racing : Intake runner 175cc, combustion chamber 60cc, maximum Valve Lift 0.600 in
BRODIX
Brodix Cylinder Heads IK 180 PKG Brodix Cylinder Heads IK 180 Cylinder Heads for Small Block Chevy | Summit Racing : Intake runner 180cc, combustion chamber 64cc, maximum Valve Lift 0.575 in
Brodix Cylinder Heads IK 180 PKG Brodix Cylinder Heads IK 180 Cylinder Heads for Small Block Chevy | Summit Racing : Intake runner 180cc, combustion chamber 64cc, maximum Valve Lift 0.525 in
Another choices available ? :)
Thanks,
Hi everybody,
TFS
BRODIX
Thanks,
Unless you are planning to race your L-82 I would go with Dart's iron factory replacements such as these: Dart 10321112P Dart Iron Eagle Platinum Cylinder Heads | Summit Racing
1 - 2 of 2 Posts
