I have an 86 with a new battery, alternator puts out 14 volts.
Disconnect the ground cable and put the multi meter in between and I have a draw of about 3 amps. I have pulled all of the fuses one at a time and disconnected (unplugged) all of the wires that I could find that could be hot when the key is off and all other switches are off and the draw remains the same.
How much loss or draw is normal? This runs the battery down in just a few days.
I have read through the posts of others that have had the same or similiar issue but have not found a post that said what the final solution was. I am sure there could be more than one solution but would think that I have tried all of the easy stuff and now need help as to what others have found the hard way. I have a battery disconnect wired in so I am able to drive the car but I would like to get this problem diagnosed. I imagine that it is not good for the ECM to be powered down by disconnecting the battery all of the time and I really want to have the car so that it functions properly.
Thanks for your help.
