1 - 2 of 2 Posts
Does an Amp pull power when the audio system and ignition is off? Mine was connected direct to the positive terminal of the battery.
That would depend on what you connected your remote wire to. The remote wire serves as the on/off switch for the amp. On an aftermarket radio this would be connected to the blue/white wire. If you are using the factory radio, the remote wire should be connected to either the accessory wire in the main ignition harness (orange) or to a fuze in the fuze box that only comes on when the key is in the acc or ign position. Hope this answers your question. :patriot:
1 - 2 of 2 Posts
