check all your vacuum lines, and your gaskets in your intake. The MAS sensor could also be loose. you can verify that it's sucking air by spraying a LITTLE (can't stress that enough) starter fluid around where the leak could be - if your idle fluctuates at all, you are in fact drawing air.
good luck!
good luck!
