If a 2 wire switch has been installed in place of a one wire switch then one wire would have to go to ground in order for a 2 wire switch to work correctly
If a 2 wire switch has been installed in place of a one wire switch then one wire would have to go to ground in order for a 2 wire switch to work correctlythe fan switch at the compressor has two wires not one. Can someone guide me as to how all this works together.
Regardless of what has been done if you ground the wire TO the fan switch or the A/c pressure switch then the fan should runhave checked fan motor direct from battery and it works. I am ready to replace temp switch. I came across the wiring diagram that shows the a/c pressure switch also controls the fan when the a/c is on. There is a high pressure switch at the compressor and a cooling fan switch connector on the compressor. .
So it would appear you have a different type of switch that has both wires going to ground ( allows you to control 2 circuits with one switch ) so grounding the 2nd wire has given a permanent ground connection on the fan circuitI just made that ground connection and the fan comes on at the turn of the key.. The fan now comes on when key in run position.
Any ideas?
:iagree:I have read that the 84 vette ECU does not control fan.?
