1 - 4 of 4 Posts
i have a 95 lt1, it was running perfect, i washed it and backed it into the garage, when attempting to take it out for a cruise it will no longer start, digital dash not lighting up, any ideas or directions would be helpful. thanks
You WASHED it? The outside or under the hood? If you washed it under the hood you may have destroyed your OptiSpark and that's most likely why it won't start now. Yeah, give us more information.
more info
borrowed service manual after speaking to a guy down the street who is a vette enthusiast, and tried to arm the vats system to see if it was working properly but the security light wont flash or nothing, no start, no click, no fire to starter, both headlights work fine, brand new battery, only washed outside of car, checked all maxi fuses, had a blown air pump fuse it was then replaced, guy next door had a obd1-2 scanner, one of those 500$ ones, and hooked it up to pull any codes but it couldn't connect for some reason. i'll try to think of anything else.
1 - 4 of 4 Posts
