Well the vapor canister collects gas tank fumes when using the stock "unvented" cap then draws "purge air" through the canister into a "ported" carburetor connection to burn off the collected fumes. If the carburetor "ported port" connection is plugged then there is no effect when the carb and engine are well tuned. But once pressure builds up in your fuel tank the unvented fuel cap will relieve pressure and fumes possibly into your garage and smell it up. I don't think the charcoal vapor cannister (CVC) has much effect but it should be connected to a ported cab connection when used.
Now the PCV works similarly but has a much greater effect on the carbs tune and engine low RPM running. But we are discussing that here unless you request so.
