The particulars
73 l-82 automatic. Recently restored. Ran fine until it started missing at running temp. Fire from distributor. Plugs soaking wet -2 middle cylinders on passenger side, two end cylinders on driver side. Changed all plugs, no avail. Raw fuel smell obvious from gas not igniting. Running HEI. New distributor. Running Carter carb with electric choke. I am thinking it is a carb problem. no obvious signs of intake issue. Took carb off to take to my carb shop. Any ideas? Thanx to anyone with an opinion.
