C6 Sprint Booster
We are always looking to take advantage of every square inch of the C6 Corvette. One way to see that this happens is to install a Corvette Sprint Booster Power Converter. The sprint booster will eliminate the delay between your gas pedal and the throttle body that is common on all drive by wire systems. The sprint booster changes the opening rate at which your Corvette’s Throttle Body opens in relation to the gas pedal operation and decreases the amount of time to achieve full throttle. This helps reaction times at the drag strip, and also helps to accelerate quicker out of turns on the road course. The C6 Corvette sprint booster gives real time control over the acceleration of your Corvette’s Engine and the best part is that it fits all C6 Corvettes including the Z06 and ZR1.
The sprint booster requires a simple plug-n-play installation that takes just a few minutes and delivers instant response throughout the C6 Corvette’s power band making accelerating and rev matching incredibly more fun. In the data graph to the right you can see the test car in red, which had the sprint booster installed, accelerated at a much faster pace then the same test car without the sprint booster through each test run. There is no doubt that by adding this sprint booster to any C6, Z06 or ZR1 Corvette that the car will reach full throttle at a significantly faster pace then the stock setup, allowing you to take off and accelerate out of turns at a much faster pace.
