I am swapping out my stock 350cid with a 383cid 405hp/450 torque from Blueprint engines (Summit Racing) and am running a new 700R4 from Monster Trans. I have a couple questions...Has anyone heard anything bad about Blueprint Engines? And when I install the motor, can I use my stock radiator if I have it cleaned, rodded and checked? I don't want to run hot if I need a bigger radiator. Can I use my stock flex plate on the engine swap from my stock engine to a crate engine? What is recommended?
Thanks, Brad
Thanks, Brad
