I put the speedo back together and I get to say 45 mph and back off, it comes back to say 35mph then it keeps on dropping down to like 10mph even thought I am now doing 40, do you think the spring that holds the cable into the speedo might need replace. If not, I am open for suggestions
thanks,
thanks,
I sounds like the $3 steel clip that prevents the drive gear from turning has broken.
Discussion Starter #5
FOund the problem, the needle was a little lose, I changed it out with another one I had, snapped it on and it worked.
