Window Motor Problems - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C3 Corvette Forums : C3 Corvette General Discussion : Window Motor Problems
XS Power
Old 06-19-2013, 09:03 AM   #1
ssclassics
Default Window Motor Problems
I have a 1981 Vette. I have a problem with the passenger side window. I can not get the motor to work up or down. I had installed a new motor about 6 months ago and it worked fine but was extremely fast. Then it just stopped working. I took it back and ordered another one. Put it in and nothing. So, I took that one back and got another one. NOTHING. I have power at the pigtail. I even put an extra ground wire on the motor housing to the door frame to make sure I was getting a good ground. Does an 81 have a window motor regulator under the console like the 78 and older does? What could the problem be?
ssclassics is offline
Old 06-19-2013, 09:23 AM   #2
fishslayer143@yahoo.com
are you sure its not jammed ? theres a front roller that is prone to come off and wedge the glass ..can you move the glass up and down?
Old 06-19-2013, 09:28 AM   #3
ssclassics
No I can not move the window up or down with the motor installed. Yes I can with it out.
ssclassics is offline   Send a Private Message Reply With Quote
Old 06-19-2013, 10:20 AM   #4
ssclassics
Any ideas???
Old 06-19-2013, 11:45 AM   #5
Lethal Tendencies
Lethal Tendencies's Avatar
can you hear the motor trying to run? Try doing a continuity test on your switch?
'77 coupe(sold) '86 coupe(sold)'98 vert (sold) '00 coupe( sold ) '85 coupe( sold ) '75 Vert ( Last one ? )
http://lethalvette.blogspot.com/
Lethal Tendencies is offline   Send a Private Message Reply With Quote
Old 06-19-2013, 02:23 PM   #6
ssclassics
No, the motor does not even try to run. Is the a relay under the console like in a 78 and older?
Old 06-19-2013, 02:50 PM   #7
Over the years I have found power window problems are usually caused by bad connections at the rocker switch. As far as the relay under the console goes I believe the same relay was used for all the C3's. The relay has an overheat switch that will stop it from working for several minutes any time it gets overheated. But before ripping everything apart check the rocker switch and make sure the connections are making a good contact with the switch.
Old 06-29-2013, 09:53 AM   #8
JOSE'S 79
did you try running the motor before you installed it?
JOSE'S 79 is offline   Send a Private Message Reply With Quote
Old 06-29-2013, 07:13 PM   #9
C3blackvette
C3blackvette's Avatar
With my 1980, the power windows have been a source of buying aspirin since I got the vette.
Put power to the window motor and confirm it works. Use a voltmeter and check the harness connector plug for power. Be careful not to damage the connectors in the plug when you insert the test leads. Don't go from one of the leads in the plug to a ground on the car, keep the 2 test leads on the plug. When you work the switch, a digital voltmeter will read power if the switch is working. When the meter shows a negative symbol in-front of the number, it means the polarity reversed for the window to go in the other direction. If you don't get correct power at the plug, you need to check the wiring to the switch.
C3blackvette is offline   Send a Private Message Reply With Quote
Old 06-29-2013, 07:37 PM   #10
sting66ray
sting66ray's Avatar
This is a power window wiring diagram for a '75. Maybe there are similarities. Hope it helps.
sting66ray is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 05:21 PM. Powered by vBulletin® Version 3.8.4
