  • Corvette Classifieds
  • SVC Store
       Share this thread: Bookmark to: Digg Bookmark to: Del.icio.us Bookmark to: Facebook Bookmark to: StumbleUpon Bookmark to: Myspace Post to: Twitter
Thread ToolsSpacerSearch ThreadSpacer Display Modes Spacer
Old 05-07-2008, 11:59 AM   #1
cmro76
Default TPI conversion
implanning to change out my air and fuel delivery system on my 78 vette. ive posted other threads on types of carbs and things like that, but now i have this idea. i wanna pull a TPI System from an 80 chevrolet and install it on mine. has anyone done this? if so how hard was it?? is it a simple drop and bolt or is there a lot more that goes into it??? thanks for any replies
cmro76 is offline   Send a Private Message Reply With Quote
Old 05-07-2008, 12:59 PM   #2
cmro76
sorry i just reread what i wrote... i plan to pull this system from a 85 - 89 chevrolet
Old 05-07-2008, 03:29 PM   #3
Lethal Tendencies
Lethal Tendencies's Avatar
I don't know how much work is involved ,but that is an excellent idea for your vette. You can pickup a TPI setup for relatively cheap. The Camaros used the TPI as well. They used a 305 but I think the IROC had the same size heads as the vette.
Lethal Tendencies is offline   Send a Private Message Reply With Quote
Old 05-07-2008, 03:45 PM   #4
TCR-02
Smokin 300HP Club
Its easier to go to an LT1 engine altogether. Much better fuel injection and more power to being with. TPI is very lacking so I would not bother with it if you dont already have it.
TCR-02 is offline   Send a Private Message Reply With Quote
Old 05-07-2008, 04:25 PM   #5
cmro76
im sort of on a budget so a whole engine wouldnt be ideal. i was just reading up a little more and most sites say that the throttle body injection works just as well and is a lot cheaper to do... any opinions on that? thanks for any feedback.
Old 05-07-2008, 09:13 PM   #6
TCR-02
Smokin 300HP Club
I guess it really just depends on what you are after. Are you trying to go fast or just trying to put efi on for a project? The tpi runners are an obstacle. With some work to them and a decent throttle body you could get a high 12 capable setup.
Old 05-08-2008, 10:03 PM   #7
cmro76
well what im really after is reliability. i just think fuel injection is the way to go... im leaning more towards TBI now, everywhere ive gone says it just as good as TPI, easier to convert, and cheaper!
Old 05-09-2008, 10:26 PM   #8
SportsCarsUnlimited
SportsCarsUnlimited's Avatar
The TPI is the easiest one to install in to your car, use the 1990 and up with the MAP senser, If you buy the painless wiring harness its a 3 wire hook up and you have to install and electric fuel pump with a return line back the the fuel tank. Can be done in a weekend.Very easy to do we have done 12 cars with this system over the last 10 years and every one loves it.
David Steele
SportsCarsUnlimited is offline   Send a Private Message Reply With Quote
Old 05-09-2008, 11:01 PM   #9
cmro76
what im bidding on is a TPI system from a 1988 corvette that had an L98 engine on it. he said its coming with the original wiring... do u think i can use that?? it doesnt come with the computer, can i buy one at any parts store and if so what should i ask for??? and finally, are there any other little things that i should be prepared for with this conversion, anything??? thanks for the help guys!
Old 05-10-2008, 11:06 PM   #10
SportsCarsUnlimited
Hello The 1988 TPI will work great, but like i said use the Painless wiring harness. This is the website. http://www.painlessperformance.com/w...rchField=60103,
It does not use the computer from the 88 corvette.
In the paper work you get with the harness it will give you a part number for the computer you need. This is so you can use a map sensor instead of the stock mass air flow meter this makes it very easy to install, Check out there site.
David Steele
« Previous Thread | Next Thread »
vB code is On
All times are GMT -8. The time now is 05:55 PM. Powered by vBulletin® Version 3.6.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2006-2007 © SmokinVette.Com
