'90 electrical gremlin and ABS - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Tech & Performance : '90 electrical gremlin and ABS
Old 02-18-2013, 02:07 PM   #1
whataboutbob90
Default '90 electrical gremlin and ABS
Hi, hope you're all staying warm. My '90,a/t,all stock has 2 problems. I don't know if they're separate or possibly related. The 1st is the clicking sound(like a relay)from under the pass. side dash. The interior lights won't come on until the clicking stops. Pressing the brake or opening the hatch usually stops it. The 2nd is the service ABS light coming on. The vehicle rolls the required distance but the hydraulic assist does not kick in. The ABS light comes on, the dash lights will flicker continuously and the engine runs rough. Turning the key to 'run' position for a few seconds before starting sometimes helps. This problem happens most of the time but not all. Any suggestions would be greatly appreciated, TIA, Bob.
whataboutbob90 is offline
Old 02-18-2013, 04:53 PM   #2
vetteoz
Smokin 2500HP Pro Road Racer
Could pull the ABS codes
ABS Codes:
Shorting pin "H" to pin "A" on the ALDL connector will cause the ABS light to flash ABS codes.
terminal H is next to G in the pic ( pre '90 shown )
Old 02-18-2013, 04:54 PM   #3
vetteoz
Sounds more like a intermittent power / ground problem
Old 02-19-2013, 01:48 PM   #4
whataboutbob90
Thanks for info. will try asap. Does car have to running or key in 'run' position, or off? Any thoughts on the 'clicking' sound? I was going to pull fuses until it (hopefully)stopped to isolate if possible. Thank you again, the vette is in storage so it may be a bit before I get to it.
whataboutbob90 is offline   Send a Private Message Reply With Quote
Old 02-20-2013, 02:20 AM   #5
vetteoz
Any thoughts on the 'clicking' sound?.
There is a courtesy lamp relay in that position; maybe it is on the way out ?
All times are GMT -8. The time now is 02:13 PM. Powered by vBulletin® Version 3.8.4
