XSPower C3 SBC & BBC Headers + Side Pipes are BACK! - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C3 Corvette Forums : C3 Parts For Sale or Wanted : XSPower C3 SBC & BBC Headers + Side Pipes are BACK!
Old 12-26-2012, 05:36 AM   #1
Superman09
Smokin Vendor
Superman09's Avatar
Default XSPower C3 SBC & BBC Headers + Side Pipes are BACK!
I am proud to announce to the C3 guys that the XSPower Longtube Header / Side Pipe systems are back. After being a supporting XSPower Vendor now for over 3 years, I am pleased to begin helping out the C3 guys
XSPower has made a few minor changes to make the C3 Small Block and Big Block systems fit and perform better than ever this time around, and check out below for information and how to order!
Small Block
Polished Stainless Steel Small Block Side Pipes from XS-Power
We have made alot of adjustments to these headers so that the fit is just right. No more steering box intereference, no pitman arm intereference and you wont need to cut your expensive to replace rocker panels!! You should be able to take these out of the very well packaged box and put them right on!!
1 7/8" primaries, 5/16" flange, 4" Collector
321 High Strength Polished Stainless Steel, Purge Tig welded
Side pipes are loaded with reverse flow glass pack mufflers.
Gaskets are included
Side Pipe mounting hardware is included.
Big Block
Polished Stainless Steel Big Block Side Pipes from XS-Power
We have made quite a few adjustments to these headers so that the fit is better than Hooker. And you shouldn't need to trim your rockers anymore!! They are pre-clearanced for the steering gear box and the frame. You should be able to bolt these on right out of the box!
2 1/8" primaries, 5/16" flange, 5" to 4" Collector
***Systems are IN-STOCK and shipping daily!***
You can order direct from the website at:
CLICK HERE TO ORDER
Also check us out now on Facebook for all the latest specials and product updates!
$25 off when you "Like" us on Facebook and use the Coupon Code found in the News Feed! :thumbs:
C3 Small Block Systems- $874.99
C3 Big Block Systems- $1149.99
1999 Silver C5
-XSPower Longtubes/X
-XSPower Catback
-232/240 blower cam
-19/20 Cray Scorpions
-Pfadt Coil-overs/Sways
407 rwhp; 12.16 @ 117
Superman09 is offline
All times are GMT -8. The time now is 09:10 PM. Powered by vBulletin® Version 3.8.4
