: C4 Corvette Forums
: C4 Tech & Performance
1986 Corvette TPI to Carb Conversion
I have just acquired a 1986 Corvette with a carbureted (chevy 350) I believe. It seems to be a wiring nightmare and I really need advice, schematics, and or wiring diagrams. The cooling fan seems to come on with the key turned to ON position. It has a fusible link. The ignition switch does not start the car. The switch must be in ON position,(fuel pump can be heard, seems to be hooked to fuel pressure regulator under hood) then flip toggle switch(PNK wire with fusible link I think), then I have to press a button to start the car. Is there a simpler way to wire this up so the switch can crank the car. I really appreciate any advice, and or help. God bless.
#2 | |
Smokin 2500HP Pro Road Racer
As everything works as it should; all you need to do is disconnect the relevant wires ( starter and ignition ) from the aftermarket switches and return them to the Ign switch at the base of the steering column where they originally came from
"Being able to "think outside the box" presupposes you were able to think in it." --Bob Lutz Last edited by vetteoz; 11-27-2012 at 08:17 PM. |
#3 | |
The cooling fan will require installing a fan switch in the head to operate it at what ever engine temp you select Something like this ( cheapest ) http://www.racerpartswholesale.com/p...n_Accessories2 or one of these http://www.ecklerscorvette.com/catal...n+kit&x=36&y=6 Instructions for install here http://www.ecklerscorvette.com/asset...ette/40416.pdf
#4 |
Thanks. I will try this diagram.
#5 |
sounds like a nightmare.....
NASCAR Winston Weekly Racing Series Track Championship Crew Member (Dirt Track) NASCAR Dodge Weekly Racing Series Track Championship Crew Member (Pavement) NASCAR Whelen All American Weekly Series Track Championship Crew Member (Pavement) NASCAR Whelen All American Weekly Series California State Championship Crew Member (Pavement) |
#6 |
The rocket launcher Ign switch and push to start buttons are " RICER " mods, not related to the carb swap.
All rather pointless because you have to have the Ign in the RUN position to unlock the steering anyway Making the fan run with the key on is typical of those that don't know how to bypass the computer control of the fan correctly when doing a carb swap
#7 |
#8 | |
#9 | |
#10 |
[QUOTE=vetteoz;640966]The wiring has been simplified ( butchered )
As everything works as it should; all you need to do is disconnect the relevant wires ( starter and ignition ) from the aftermarket switches and return them to the Ign switch at the base of the steering column where they originally came from I reconnected and nothing. I will trouble shoot more on this tomorrow. Any suggestions.
All times are GMT -8. The time now is 07:25 PM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
