Need Help! Starting Issue - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : Need Help! Starting Issue
1984 - 1996 Corvettes
Old 11-20-2012, 03:43 PM   #1
1994MLC
1994MLC's Avatar
Unhappy Need Help! Starting Issue
My Bad. Detailed my 94 coupe in preparation for winter storage. Pressure washed the engine compartment (ran for 10 minutes after). Then detailed the rest of the car and fixed a few things. Went to start the engine; turns over but no spark. It's obivious I got something wet. But what? I blew off everything with compressed air three times. I fired up the torpedo heater (garage is at 100 degrees). Not quite sure where to go from here. Any ideas? Do you think after time, things will dry out enough for engine start?
1994MLC is offline
Old 11-20-2012, 07:38 PM   #2
Slicktop
Slicktop's Avatar
Probably got moisture in the optispark distributor. If so there is no way to dry it out without removing it and taking it apart.
Old 11-20-2012, 08:27 PM   #3
vetteoz
Smokin 2500HP Pro Road Racer
There are reasons why you don't do that on a LT1
http://www.theformulasource.com/foru...howtopic=16824
http://www.impalassforum.com/vBullet...87&postcount=9
Old 11-21-2012, 04:56 AM   #4
1994MLC
1994MLC's Avatar
Nice. Seemed like a good idea at the time. Done this many times before on other vehicles. This might be one of those situations where I say, "I'll never do that agian!" Looks like this is going to be a real P.I.T.A. Thanks to the both of you. I now have starting point. Great links, very helpful.
1994MLC is offline   Send a Private Message Reply With Quote
Old 11-21-2012, 09:05 AM   #5
mat helm
mat helm's Avatar
I too have pressure washed many engines. My routine is to warm it up and leave it running during and well after using the pressure washer. But what you can't do is use it like you would a sandblaster. I think the idea is to not subject it to much more than it would see going down the road at 70 in a blinding rain storm, which means keeping your distance with the wand. I use westley's tire cleaner, and mostly use the pressure washer to clean the rubber n plastics. You can get some of the grease n crud build up, but only after you've hand scrubbed it lose. I've never had an issue, but you are always taking a chance.
One thing to consider in you instance, is you maybe found a weak point in your opti spark that would of left you broke down on the side of the road in a rain storm.
btw, you could try spraying down the opti with some WD40. It was made to displace water in this exact instance. It also contains no oil, so no eating away on the electronics.....
mat helm is offline   Send a Private Message Reply With Quote
Old 11-21-2012, 09:53 AM   #6
lostvette
lostvette's Avatar
Default Starting!
I have a 88 With a Hei ! & all the storys I've Heard!.... about OPTI SPARK SUCKS !
lostvette is offline   Send a Private Message Reply With Quote
Old 11-21-2012, 03:50 PM   #7
1994MLC
1994MLC's Avatar
Default Starting issue
As I was tracing the ignition leads, I found possibly a related/un-related problem. The number 5 lead was resting against the exhaust manifold. As I was inspecting it, the lead seperated. Certianly was a break-down waiting to happen. What are your thoughts? Do you think I have two problems? Optispark and the #5 lead??
Old 11-21-2012, 05:26 PM   #8
mat helm
mat helm's Avatar
One lead grounding out won't keep it from starting, so I'd say you have two...
Old 11-22-2012, 05:35 AM   #9
crossflag
Smokin 400HP Club
crossflag's Avatar
I agree, While recently checking for clearance with roller rockers under the covers I pulled 4 plug wires while my buddy tapped the engine over. The engine still started! A few years back I did my opti in doing the very same thing! Also did in the knock sensors on my 04 silverado by washing the engine. On the bright side, instead of storing your car you now have A winter project!
Wrap ur Azz in Fiberglass
crossflag is offline   Send a Private Message Reply With Quote
Old 11-22-2012, 05:52 AM   #10
crossflag
Smokin 400HP Club
crossflag's Avatar
These are not worth while taking apart with all the work to get to them.
I recomend changing the water pump while your at it
All times are GMT -8. The time now is 01:43 AM. Powered by vBulletin® Version 3.8.4
