guestion(s) concerning 94 electrical circuitry - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : guestion(s) concerning 94 electrical circuitry
1984 - 1996 Corvettes
Old 11-17-2012, 02:17 PM   #1
Anthony Dale Enloe
Default guestion(s) concerning 94 electrical circuitry
Ref: 1994 Owners Manual, pages 220-222.. With key in off position (car locked) which circuit is still hot. In other words, it can be operated with the key off. For example the Hazard Flashers / Brake switch still has power, also the hatch or deck lid release still has power to it. What others circuit(s) might still be active with the key off. If you have the manual let me know which fuse(s) by number which would qualify. I'm trying to hunt down a short in the car.. Thanks for your help or any suggestions.
Anthony Dale Enloe is offline
Old 11-17-2012, 05:30 PM   #2
vetteoz
Smokin 2500HP Pro Road Racer
Originally Posted by Anthony Dale Enloe View Post
I'm trying to hunt down a short in the car.. .
A short or a power drain ?
A direct short will blow whatever fuse is feeding it
With key in off position which circuit is still hot. In other words, it can be operated with the key off..
Several circuits are fed direct from the battery with protection from fusible links , not the internal fuse panel
Old 11-18-2012, 05:57 AM   #3
toobroketoretire's Avatar
Anthony, your digital voltmeter will have a scale that will go up to about 10 amps. You just have to plug the hot terminal into the "amp" terminal. Then disconnect your battery cable and put the amp gauge in between the disconnected connections and see how many amps it's drawing. That will give you a clue. Most often small draws come from either the dome light or courtesy lights. And if your car has an underhood light that uses a mercury switch it may be out of adjustment and burning when your hood is closed.
Old 11-19-2012, 10:03 PM   #4
vetteoz
Start pulling the fuses out to see if the amp draw changes.
If it doesn't then you know the drain is not from one of the fused circuits
Old 11-19-2012, 11:33 PM   #5
vette82forme
The CDM and bose amps can cause a weird power drain. My 90 had this and some days would be fine and others battery would die.
vette82forme is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 03:55 PM. Powered by vBulletin® Version 3.8.4
