: C5 Corvette Forums
: C5 Tech & Performance
New owner... problems already
| Sponsored by TKO Performance |
Hi, everyone. A few weeks ago I bought a 99 with 50k, to my knowledge stock except for flowmasters. I haven't even pushed it yet and I've been having a blast just cruising around town, couldn't be happier. Until yesterday.
Before I begin, I changed the plugs and wires the day after I got it. Granatelli wires and ngk t5's Yesterday morning on my way to work I noticed a bit of a rough idle, and sometimes when I'd come to a stop it would start surging and making a grinding like noise. If I put it in park and back into D it stops.I then noticed a surging while driving between 70 and 80 mph on i95. No loss of power, no codes, and I'd say the surging at a stop happened 2 out of 10 or more stops. Its in general idling like it has a cam now Freakin out please help! |
#2 |
Welcome.
I had a similar situation when I changed out the wires and plugs on my '66 (I know, it's not a C5) and all it was was that I didn't push hard enough on the wire cap on one of the plugs. That was an easy fix for me but since I did nothing else to warrant rough idling, and shitty performance, I figured the connection between wires and plugs had to be the culprit. Hope it helps. |
#3 | |
#4 |
since it started after the new wires installed, I would check your plug wire on number 7... it is very close to the metal tube/pipe from A.I.R. .. mine burned thru and was arcing to the tube causing rough idle and misfires at cruise speed...open your hood at night, you should see the spark jumping
#5 | |
Strange thing is I drove it around in the morning after I did all the checks and no problems, went out again in the afternoon and it happened again, 1 time out of atleast 10 stops. strange and If I put it in park and go right back into D it stops.
#6 |
Loose/bad engine ground ?
NASCAR Winston Weekly Racing Series Track Championship Crew Member (Dirt Track) NASCAR Dodge Weekly Racing Series Track Championship Crew Member (Pavement) NASCAR Whelen All American Weekly Series Track Championship Crew Member (Pavement) NASCAR Whelen All American Weekly Series California State Championship Crew Member (Pavement) |
#7 |
Sounds like it could be the MAF sensor.
#8 |
I'm going to try cleaning the maf and the TB, hopefully it does something.. theres a thread on the c4 forums that matches my situation and that ended up being the problem. Thanks guys
All times are GMT -8. The time now is 09:59 PM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
