: C4 Corvette Forums
radiator hose hot and cold
have a 96 vette lt1 motor in 84 pickup, all hooked up with reverse flow. my lower hose is always cold motor runs great never overheating is cold hose normal? heater and everything good.
#2 |
What does the temp gauge read? With the rad. cap off and engine warm do you see a flow?
Wrap ur Azz in Fiberglass |
#3 |
hate to sound dumb, temp gauge is 180 approx. where is rad.cap on reverse flow rad????????? thanks
#4 |
If the motors running temp is 180 thats good. Drive it and enjoy
#5 | |
Smokin 2500HP Pro Road Racer
Are you using the stock pickup radiator or a Vette style radiator with the remote coolant bottle. Reverse flow only affects the direction the coolant flows
#6 |
Are you talking about a reverse rotation water pump? Normally a cold lower hose means that your thermostat is not opening. If your temp sensor is not in coolant, it may not be reading properly. Good luck
Toby |
#7 |
Reverse rotation pump only spins the opposite way , coolant flow through engine is still the same
Gen II LT1 is reverse flow through the block ; not the pump. Coolant goes to heads first as opposed to the block first as with all Gen I SBC's Also in stock LT1setup the coolant flow through the radiator is reversed The thermo outlet goes to the bottom of the radiator and cool coolant goes back to engine from the top Makes no difference . My Gen 1 Camaro with a LT1 has the radiator hoses connected the conventional way; hot to top and cool from bottom
#8 |
True but he stated the heater worked fine. Im thinking it has a 180 thermostat.
All times are GMT -8. The time now is 11:57 AM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
