P219A - anyone get this code? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C6 Corvette Forums : C6 Corvette General Discussion : P219A - anyone get this code?
2005 + Corvettes Sponsored by
B&M Racing
Old 10-23-2012, 06:52 AM   #1
tkogto
Default P219A - anyone get this code?
Looking for a solution to fix this recurring code. Sometimes it happens after 40 miles after being cleared, sometimes it takes 150 - 200 miles to reoccur. I notice no drop in performance, rougher idol, etc. Car has been checked for a vacuum leak - nothing. I do have a breather cap on the oil but have had it for much longer than I've had the code issue.
Swapped the o2 sensors this weekend to see if code followed the sensor over to the other bank - no go, still left bank. Also have switched back and forth between aftermarket and stock tune. Get same code with either tune.
Any ideas?
Posted same in Scan & Tune but with last post on that forum from June, I added it here as well.
Google definition of code is: The Fuel Trim Cylinder Balance diagnostic detects a rich or lean cylinder to cylinder air/fuel ratio imbalance. The diagnostic monitors the heated oxygen sensor (HO2S) signal frequency and amplitude characteristics by calculating an accumulated voltage over a predetermined sample period. An imbalance is indicated when multiple samples of the accumulated voltage are consistently higher than the desired value.
tkogto is offline
Old 10-23-2012, 07:19 AM   #2
Pappytinker
Smokin 2500HP Pro Road Racer
Pappytinker's Avatar
Just a thought
http://img3.targetimg3.com/wcsstore/...4/13547593.jpg
or
http://www.autobahnpower.com/images/Tn_Bg44K%200593.jpg
or
http://www.amsoil.com/storefront/ima...tle_300pxh.jpg
"Because of the one-pointed time awareness in which the conventional mind remains immersed, humans tend to think of everything in a sequential, word-oriented framework. This mental trap produces very short-term concepts of effectiveness and consequences, a condition of constant, unplanned response to crises." Liet-Kynes - Dune
Old 10-23-2012, 07:43 AM   #3
tkogto
Interesting. Now that I think about it, I didn't start getting the code until after I used a fuel injection cleaner earlier in the year. I wonder if the cleaner might have loosened something a bit and that is what is stuck now?
tkogto is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 07:09 AM. Powered by vBulletin® Version 3.8.4
