Intermittently Won't shift out of park.... - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C6 Corvette Forums : C6 Corvette General Discussion : Intermittently Won't shift out of park....
2005 + Corvettes Sponsored by
B&M Racing
Old 10-12-2012, 07:10 AM   #1
Cheetah2010
Default Intermittently Won't shift out of park....
I know this has been discussed, but if anyone got their problem fixed, please let me know what to suggest to the dealer. I am guessing GM PART # 15277559
CATEGORY: Transmission Shift Control will have to be replaced and hope that does it????
Cheetah2010 is offline
Old 11-28-2012, 11:10 AM   #2
Hotrod
Hotrod's Avatar
Post
Try checking the brake pedal switch. This switch activates a relay which in turn powers the solenoid to release the shifter from park.
Old 12-06-2012, 05:02 AM   #3
thecorvettemechanic
HI there,
Both items, the brake switch and/or the brake transmission shift interlock solenoid could be the culprit.
What I would suggest is to listen for the brake lamp relay click below the passenger side toe board. If you have the click, the information is getting to the BCM to release the solenoid and you have a sticking shifter assembly.
But I would be thinking shifter assembly/solenoid than the brake switch.
Allthebest, TCM
thecorvettemechanic is offline   Send a Private Message Reply With Quote
Old 12-09-2012, 05:49 PM   #4
C6RaceCar
Could this be from the shift lock issue with the 05 cars
C6RaceCar is offline   Send a Private Message Reply With Quote
Old 12-10-2012, 06:25 AM   #5
thecorvettemechanic
Most definately could be the same condition.
Allthebest, tcm
All times are GMT -8. The time now is 06:06 PM. Powered by vBulletin® Version 3.8.4
