sports seat issue in 94 coupe - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : sports seat issue in 94 coupe
1984 - 1996 Corvettes
Old 09-22-2012, 06:19 PM   #1
Anthony Dale Enloe
Default sports seat issue in 94 coupe
OK SV gang, had disconnected and pulled drive seat to aid trouble shooting cruise control issue under the dash. Well to make a long story short after hooking the seat back up and testing the seat function all seem to be in order, so I switched the selector switch(on console) from the drive seat to the passenger side and found that the passenger seat was non functional. Reguardless of which position the seat select switch was in the driver seat moved in both position. So were does one find this switch and what all has to be removed to replace it?? Thks for any and all help or advice..
Anthony Dale Enloe is offline
Old 09-22-2012, 07:20 PM   #2
Slicktop
Slicktop's Avatar
Suggest replacing the seat select switch. Get it from the dealer or if it is a nla part get the gm part number and do an internet and ebay search for that part number and you should be able to find one........
Old 09-22-2012, 07:28 PM   #3
BAD-C5
BAD-C5's Avatar
BAD-C5 is offline   Send a Private Message Reply With Quote
Old 09-23-2012, 06:35 AM   #4
mat helm
mat helm's Avatar
You may have just pulled the connector lose from the switch....
mat helm is offline   Send a Private Message Reply With Quote
Old 09-25-2012, 11:16 AM   #5
Anthony Dale Enloe
Default fixed problem with sport seats
Well I'm learning more each day. As it turned out the problem was not the lumbar selection switch. It was how I reconnected the wiring harnish under the driver seat. Logic would dictate that difference gauge wires would not be plugged/ connected to each other (at least for me), but on the sport seats for 1994-1996 thats how GM designed it.
"If you plug the large gauge wire connector to the other large gauge wire connecter your passenger seat will not move.."
You have to connected/plug large gauge wire connector to small guage wire connector. For those that have not pulled their driver side sport seat the connectors both male/female for both the large gauge wire and the small gauge wires are the same size.. And word of caution this wiring combination is for those that have seats with all the same options.
Anthony Dale Enloe is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 10:36 AM. Powered by vBulletin® Version 3.8.4
