Headlight actuator draw - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : Headlight actuator draw
1984 - 1996 Corvettes
Old 09-11-2012, 07:37 AM   #1
RedVette2
RedVette2's Avatar
Default Headlight actuator draw
Well I replaced one of my headlight actuators (that flips the headlight). The new one works but keeps making a clicking noise and draws electric current when closed. Any idea what the problem is?
Thanks for the replies in advance
Paul
87 c4
RedVette2 is offline
Old 09-13-2012, 02:05 PM   #2
95vette
95vette's Avatar
On an early version it is bad gears, later version it is bad bushings in the gear housing.
95vette is offline   Send a Private Message Reply With Quote
Old 09-13-2012, 02:07 PM   #3
Seabee 86
Seabee 86's Avatar
Send a message via AIM to Seabee 86
It sounds like it keeps trying to close the light even though it's closed. Maybe a dirty relay?
"General Malfunction"
Seabee 86 is offline   Send a Private Message Reply With Quote
Old 09-13-2012, 02:13 PM   #4
95vette
95vette's Avatar
No, it is in the gear housing on the motor. Something is slipping, so not sufficient resistance at first for the motor to stop working right away. It wll just get worse if not fixed. 84-86 years need new gears, 87-96 need new bushings. A one hour DIY job and just a few dollars for the delrin bushings.
Old 09-20-2012, 09:54 PM   #5
C4Steve
C4Steve's Avatar
Had the same thing with the same symptoms after replacing my '88's actuator. Replaced the bushings and round gear (not worm gear) in both motors and it's been fine since. Figured the new gears were cheap money in case I found them chewed up and had to wait for another shipment. The old bushings came out in crumbs when I opened it up.
C4Steve is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 04:39 AM. Powered by vBulletin® Version 3.8.4
