: C4 Corvette Forums
: C4 Tech & Performance
85 vette hard to start
HI GUYS
I HAVE AN 85 VETTE AND ITS GETTING HARD TO START IT IS GETTING FIRE AND ITS GETTING GAS JUST A LITTLE HARD TO STAT WHEN ITS COLD SHOULD I GET A CAN OF CHOKE CLEANER AND SPRAY THE HECK OUT OF THE THROTTLE BODY IM OPEN TO SUGGESTIONS THANK YOU FOR THE HELP JEFF |
#2 |
Have U Cked The Spark Plugs ?
#3 |
We need more info, my diagnosis would be different from a car with 100k to a car with 10k. Could be a battery, could be plugs...does it fire right up when it starts or does it struggle to get to idle speed?
"General Malfunction"
#4 |
Hi Guys
I worked on my vette today and last night I think I found the problem I sprayed the heck out of the trottle body and put some cleaner in the tank took down the highway and blew the cobs out of it i think im haveing a battery problem or lose cabel to the starter it will fire up now with no probelems the car has 100.00 plus miles on it has new plugs wires ect thanks for the input Jeff |
#5 | |
When you say "it's getting a little hard to start" are you saying it spins over but takes an abnormally long time to fire off? And does it crank fast enough? It should crank at around 550-600 rpm or as fast as it would normally idle when warmed up. If it cranks slow it could be as simple as dirty battery cables or a weak starter. |
All times are GMT -8. The time now is 04:48 AM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
