Dana 36 to Dana 44 Conversion - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Tech & Performance : Dana 36 to Dana 44 Conversion
Old 09-06-2012, 09:19 AM   #1
ChadroletZ52
ChadroletZ52's Avatar
Default Dana 36 to Dana 44 Conversion
Just got my new 383 HSR built and putting out 492hp. Built the 700R4 up pretty solid and now I am moving on to the rear! I have looked in past threads and could not find what all has to be done for the conversion. For sure the diff and batwing and the driveshaft and ladderbar? Not sure what all i need to aquire to make the swap happen. Also what years of the batwing diff and ladderbar will mount my 700r4 and bolt up to suspension? Thanks for the help!
ChadroletZ52 is offline
Old 09-06-2012, 10:43 AM   #2
fishslayer143@yahoo.com
I would think the driveshaft will need to be shortened, since the 44 is about 1 inch longer, and there may be some bolt hole modifications necessary.. if you can t find a 44 batwing, I m told there is an adapter plate to use with the 36 batwing .. the Dana 44 is certainly stronger, but do not think that it is indestructible..I have a Duntov Built Dana 44 in my C3 behind a 525HP /383., 700r4...4 years now and its still together, but I do not run slicks, ever!.. good luck.
Old 09-22-2012, 11:28 AM   #3
Calderone
I did this conversion
Easier and cheaper at the long run is to
build a D44 with all fresh internal parts, so you'll avoid any possible future problems.
I got a D44 with its own batwing, driveshaft and c-beam, the c-beam is identical to the D36 but the bolt holes are in a slightly different possition.
Faster and easier if you do it that way.
Pretty straightforward swap !
Good Luck with it !
btw , i stepped up from 3.07 to 3.45's with the swap.
Calderone is offline   Send a Private Message Reply With Quote
Old 09-25-2012, 05:50 AM   #4
vetteoz
Smokin 2500HP Pro Road Racer
The D44 batwing and diff head are a bolt in replacement for a D36 unit reusing all your existing rear suspension parts
Some have done the swap reusing the D36 DS and redrilling the front C Beam holes
http://www.joby.se/corvette/mods/2001-0X11_diff/
All times are GMT -8. The time now is 09:14 PM. Powered by vBulletin® Version 3.8.4
