: C3 Corvette Forums
: C3 Tech & Performance
Swapping In A TH700R4
One of the very best swaps you can ever make is replacing a TH350 or TH400 with a TH700R4. When I bought my 454" powered '71 I knew the TH400 would have to go because of the horrendous fuel mileage I would get. So after plunking down $350 at the local wrecking yard I came home with a totally worn out TH700R4 out of a 1991 van.
To tolerate the extra torque of the 454" I rebuilt the TH700R4 with performance aftermarket parts then made the swap in only one day; the total cost being around $1700 (which included the drive shaft cutting, the new tail housing with a mount pad, and heavy duty torque converter). With the TH700R4 I can cruise at 70 mph at only 1800 rpm and get around 16 to 17 mpg; about 4 more than I would have gotten with the TH400. Fish was the first SmokinVette member to swap one in and I was the second. And since I made the swap several others have made the swap. Why run an obsolete transmission when the fantastic 30% overdrive TH700R4's exist? Last edited by toobroketoretire; 08-18-2012 at 11:22 AM. |
#2 |
I ll drink to that!!I love mine!
#3 |
#4 |
the 700R4 is an item I waited to long to convert to
and for me it was $780 and 2 weeks long (got a pro to do it)
Gun control is not about guns it's about CONTROL
#5 |
you got a great deal!..all together I spent about $1900 on the complete conversion, shifter conv. , new double wall drive shaft and HD joints, and stall speed ..all labor was mine [ a labor of love, of course] ...... but mine is rated for about 650 HP
#6 |
how much HP can a stock 700 handle?
all mine has is a shift kit (semi-manual shift kit) never used a 100 shot with it. And dont know how much it can handle the monster in a box is $500 and labor is $300 dont wanna spend that if a dont have too the motor makes like 300HP
#7 |
is it a first generation 700r4? if so, not much, smaller input shafts...... if its a later year, it should handle a 100 shot..besides, with stock tires you probably won t get enough traction to hurt anything..if you want more, then all you need ,is to improve yours with better clutch pacs and a Fairbanks Servo, etc.
#8 | |
its also a 91 and dont know if the clutch pacs are new but they have lasted 7 months (about 700 miles) driving the car like I stole it and the oil is still fresh
#9 |
thats a second generation so should be good to go if its in good shape ...enjoy!
All times are GMT -8. The time now is 11:06 AM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
