L-82 Option - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C3 Corvette Forums : C3 Corvette General Discussion : L-82 Option
XS Power
Old 07-31-2012, 02:46 AM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
Default L-82 Option
What year did they start the L-82 motor option?
'77 coupe(sold) '86 coupe(sold)'98 vert (sold) '00 coupe( sold ) '85 coupe( sold ) '75 Vert ( Last one ? )
http://lethalvette.blogspot.com/
Lethal Tendencies is offline
Old 07-31-2012, 10:16 AM   #2
fishslayer143@yahoo.com
it came out in 73 to replace the LT1 which was dropped in 72.... not even close as a substitute .. over 100 HP reduction
fishslayer143@yahoo.com is online now   Send a Private Message Reply With Quote
Old 07-31-2012, 10:34 AM   #3
toobroketoretire's Avatar
Yeah, the 370 hp LT-1 was a serious performance engine but the replacement L-82 was just a barely warmed-over 350". Like comparing oranges to grapes..................
Old 08-13-2012, 02:11 PM   #4
7t9l82
Smokin 50HP Club
7t9l82's Avatar
thats not exactly fair or true. the L-82 short block is identical to the LT-1 with the exception of the 350/350 cam. it also had an inferior intake ,both engines were rated differently. the cam in the L-82 is better down low, it will pull hard out of the hole the LT-1 is better on the top end. a L-82 is easy to get into the 13 second range I've done it many times.
7t9l82 is offline   Send a Private Message Reply With Quote
Old 08-13-2012, 03:34 PM   #5
I disagree.. the rating for the 72 LT1 is 330 Net HP after the 70 was rated the old way at 370 Gross HP.. the L-82 was 220-250 [ depending on year] Net HP , the exact same way of rating HP..big drop due to reduction in Comp ratio, chamber size and a weaker hyd cam , and a Q-jet carb w/different intake ....the LT1 1/4 mi was low 14 s and the L82 was mid 15s in stock forms .. I have owned several of each, and there is no comparison.. the L82 is just a good 4 bolt Forged bottom end starting point for a good street motor .. and when coupled to a th350 it was really obvious how weak it was....and yes you can make it get in 13 s as you can with any engine, even an L48 , but we are talking about right from GM..not that the L82 isn t a perfectly good motor that lots of owners are happy with, but from a performance perspective, it comes from the time of reduced power for lower emissions smog motors...Oh by the way the difference between gross and net HP is about 40-50hp, net =with accessories attached . , gross=w/o accessories [ waterpump, alternator ,P/s pump,fan,etc. ]
Old 08-14-2012, 09:12 AM   #6
7t9l82
Smokin 50HP Club
7t9l82's Avatar
block ,crank ,rods and pistons are the same in the 71-72 Lt-1 and the L-82 all years. only the 70 LT-1 had 370 horsepower. after 72 they retarded the cam 4 degrees hurting power more. an L-82 on a dyno makes a little over 300 horsepower. the auto makers were also playing with ratings for insurance purposes. i also have had a 70 LT-1 roadster A L-82 pace car (new) a 68 L-88 roadster and several other c3 era corvettes. i stand by my comments
Old 08-14-2012, 09:58 AM   #7
C3blackvette
C3blackvette's Avatar
1973 saw a radical change in engines! The gas crunch and emissions standards change the industry.
C3blackvette is offline   Send a Private Message Reply With Quote
Old 08-14-2012, 11:51 AM   #8
sorry, don t want to argue, but you are mistaken..and I too ,have owned 11 C3 s and worked on hundreds.. the LT1 had 11:1 dome pistons ,special forged crank ,... the L82 never had anything but 9.5 :1 flat tops.. I owned several of each and rebuilt several of each... and if your L82 ever made 300 HP, it was on a dyno stand with nothing attached, which is GROSS not NET HP, and not in the same form as it came.... .and it wasn t just the engine, the entire LT1 car was more performance fitted...but don t take my word ..heres the original RPO Details & Specifications
History
" Chevrolet first introduced the RPO LT-1 motor package in 1970. With 370 gross horsepower at 6,000 RPM, it featured many hi-performance and heavy duty components, including solid lifters, heavy duty starter, forged TRW aluminum pistons, 11:1 compression, four bolt main cap block, Tuftrided crank, special hi-lift cam, high rise aluminum intake, Holley carb, baffled oil pan, and transistor ignition. Also included were larger capacity components also not found on the base 350, such as a larger rad, hi volume oil and fuel pumps, and 2 1/2 inch exhaust. Stock 1970 LT-1 Corvettes were reported at the time to be able to achieve 0-60 in 5.7 seconds, and do the quarter mile in 14.2 seconds."...............the L82 came with almost none of that.. in stock form , it was not a performance PKG like the LT1 was..and again, theres a lot of happy L82 car owners around, but to say it was comparable to the LT1 cars in their stock factory form, is not accurate by any means
Old 08-14-2012, 12:03 PM   #9
you are correct, between new emission standards and the big Insurance lobby, Corvette performance was cut off at the knees .. it was more than a decade before Corvettes started regaining HP
All times are GMT -8. The time now is 06:21 PM. Powered by vBulletin® Version 3.8.4
