A/C, Heat, Defrost air flow - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : A/C, Heat, Defrost air flow
1984 - 1996 Corvettes
Old 07-28-2012, 05:00 AM   #1
Coachg
Default A/C, Heat, Defrost air flow
1984 When the fan is turned on and any of the A/C, Heat or defrost options are selected (the air temperature is as selected) the fan blows through all of the outlets. I replaced the vacuum tank but the "door" that close off the other passages do not respond, air still flows out of all the outlets. What else can I check?
Coachg is offline
Old 07-28-2012, 06:18 AM   #2
toobroketoretire's Avatar
Originally Posted by Coachg View Post
I replaced the vacuum tank but the air still flows out of all the outlets. What else can I check?
We need a lot more information before we can help you; like which year and the rest of the details. Are you saying air flows out of all your vents even when your heater and A/C controls are turned off?
Old 07-28-2012, 07:09 AM   #3
Slicktop
Slicktop's Avatar
Check the climate control panel to make sure that all the connectors are hooked up/plugged in behind it. Check vacuum lines. Can not be more specific since I have never had that particular problem with my C4.
Old 07-30-2012, 10:09 AM   #4
Hotrod
Hotrod's Avatar
Post
Check for leaks on all the actuators, they are vacuum controlled. The actuators divert airflow to the different outlets depending on which mode of operation you select. I believe there are three in all. Actually, its best to start at the vacuum source and trace the vacuum lines thruout the system. Start at the vacuum tank under the hood and then to the control head at the HVAC control panel and then to the vacuum actuators.
All times are GMT -8. The time now is 08:38 AM. Powered by vBulletin® Version 3.8.4
