bad bucking... sumtimes - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Tech & Performance : bad bucking... sumtimes
Old 07-22-2012, 07:11 PM   #1
louierepo
Question bad bucking... sumtimes
I have a 1994 lt1 with 70k, car is cherry. Lately when driving and you try to accelorate she starts to buck, the harder u try to go the worse the buck is and a puff of black smoke. Mechanic has car for over two weeks now and doesn't have a cleu at what it is. Has no lights on or codes in computer. Gas is clean and 94 octane fuel filters are new and still does it. Any thoughts guys, thanks
louierepo is offline
Old 07-22-2012, 07:41 PM   #2
Seabee 86
Seabee 86's Avatar
Send a message via AIM to Seabee 86
Shooting from the hip I would guess a fuel pump.
"General Malfunction"
Seabee 86 is offline   Send a Private Message Reply With Quote
Old 07-22-2012, 08:09 PM   #3
lostvette
lostvette's Avatar
Default bucking
Change Mechanics Too !
lostvette is offline   Send a Private Message Reply With Quote
Old 07-23-2012, 05:23 AM   #4
Pappytinker
Smokin 2500HP Pro Road Racer
Pappytinker's Avatar
Just a guess;
http://www.buzzle.com/articles/sympt...regulator.html
"Because of the one-pointed time awareness in which the conventional mind remains immersed, humans tend to think of everything in a sequential, word-oriented framework. This mental trap produces very short-term concepts of effectiveness and consequences, a condition of constant, unplanned response to crises." Liet-Kynes - Dune
Old 07-23-2012, 06:45 AM   #5
toobroketoretire's Avatar
First have your mechanic check the fuel pressure. Then have him pull the spark plugs and see what they look like. If they all look good have him do an ohm test on each of the wires.
Old 07-23-2012, 09:44 AM   #6
Hotrod
Hotrod's Avatar
Post
A black puff of smoke would indicate a rich mixture. Check your ignition system, the ign. coil could be on its way out or the feed for the coil or even the trigger for the coil. Had a problem like this before and it turned out to be a pinched ign. coil wire , the 12V feed.
All times are GMT -8. The time now is 05:05 AM. Powered by vBulletin® Version 3.8.4
