smog control - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Corvette General Discussion : smog control
1984 - 1996 Corvettes
Old 07-18-2012, 07:27 AM   #1
_charliebrown_
_charliebrown_'s Avatar
Default smog control
Hi, My A.I.R. pump is making noise. How much of a job it is to remove the all the smog equipment and what are the conquences?
_charliebrown_ is offline
Old 07-18-2012, 07:49 AM   #2
Slicktop
Slicktop's Avatar
The AIR system is a balanced one and your engine should actually run better with it in place. It would be a big job to remove it with no real benefit for a street car. Suggest just replacing the AIR pump. It is cheap and easy to do:
http://www.autozone.com/autozone/par.../N-iif7dZ9ixre
Old 07-18-2012, 05:44 PM   #3
toobroketoretire's Avatar
Originally Posted by Slicktop View Post
The AIR system is a balanced one and your engine shoud actually run better with it in place. It would be a big job to remove it with no real benefit for a street car. Suggest just replacing the AIR pump. It is cheap and easy to do:
I agree with Slicktop as it's way more trouble than it's worth to remove everything. Rebuilt smog pumps are real cheap and will usually last 100,000 miles or more. Then down the road the next owner will likely thank you for keeping it original as he might be subject to smog tests in his area.
Old 07-29-2012, 10:59 AM   #4
robs1988
Smokin 2500HP Pro Road Racer
robs1988's Avatar
I disagree in it being a big job to remove. I removed all the air parts in a only a few hours. I didn't notice any difference in how it ran, but it did seriously cleanup the appearance under the hood. I also removed the innards of the smog pump itself and left it in place so that I didn't have to mess with fitting a different belt.
If your state smog tests then I would leave it be.
robs1988 is offline   Send a Private Message Reply With Quote
Old 07-29-2012, 12:30 PM   #5
Slicktop
Slicktop's Avatar
So you drive arround with a check engine light on all the time? Also, if you left the smog pump so that you would not have to change the drive belt system you did not accomplish the hardest part of removing the smog equipment, and did not remove the biggest piece of equipment, the pump. You really accomplished nothing........except to mess your car up. I would not recommend that to anyone.
Old 08-14-2012, 05:03 PM   #6
Wingnut
Wingnut's Avatar
Cool A i r pump
Leave the pump buy a shorter belt and run it UNDER the pump. You can also take the iners outlooks stock let the next guy figure it out
Wingnut is offline   Send a Private Message Reply With Quote
All times are GMT -8. The time now is 07:47 PM. Powered by vBulletin® Version 3.8.4
