1986 Corvette ignition problem - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Tech & Performance : 1986 Corvette ignition problem
Old 07-07-2011, 11:52 AM   #1
Jim Hannon
Default 1986 Corvette ignition problem
I have a 1986 Corvette that has a miss and runs rich. In the process of elimination I have tested the coil, pickup coil is new, Cap and rotor new, MSD spark plug wirers test with in range. I hooked it up to a timing light and the spark is very erratic on every cylinder. Timing light is working correctly have tested it on another vehicle. I can not seem to figure this out!!!! Any help will be greatly appreciated.
Jim Hannon is offline
Old 07-07-2011, 12:01 PM   #2
Vettemagnet
Do you have a CEL on?
Vettemagnet is offline   Send a Private Message Reply With Quote
Old 07-07-2011, 12:19 PM   #3
Jim Hannon
What is a CEL?
Jim Hannon is offline   Send a Private Message Reply With Quote
Old 07-07-2011, 12:21 PM   #4
Vettemagnet
Originally Posted by Jim Hannon View Post
What is a CEL?
Check engine light.
Old 07-07-2011, 12:25 PM   #5
Vettemagnet
This almost sounds like a electronic spark control issue (ESC). Check your codes and let us know.
Old 07-07-2011, 12:30 PM   #6
Jim Hannon
No codes other than the 42 when timing it. Cleared all codes now nothing after driving for 30 min or more.
Old 07-07-2011, 12:54 PM   #7
Vettemagnet
Code 42 is EST - electronic spark timing.
When you see 42 or 43 it's usually a knock sensor that is part of the ESC system. This is the system that advances or retards the timing.
Old 07-07-2011, 12:58 PM   #8
Vettemagnet
How does it drive? Did it go away?
Old 07-07-2011, 01:17 PM   #9
Jim Hannon
Only got code 42 when I unhooked the EST plug to set the Base timing, that is when I noticed the erratic spark. Seems to drive well other than running rich and rough idle.
Old 07-07-2011, 01:29 PM   #10
Hotrod
Hotrod's Avatar
Question
It could be a worn dist. gear. What weight oil are you using?
All times are GMT -8. The time now is 09:56 PM. Powered by vBulletin® Version 3.8.4
