1977 Tranny, drive and halfshaft questions - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C3 Corvette Forums : C3 Tech & Performance : 1977 Tranny, drive and halfshaft questions
Old 06-13-2011, 10:18 AM   #1
cctroupe09
Default 1977 Tranny, drive and halfshaft questions
Hey guys, my 77 Vette has the 3 speed automatic in it, I was wondering what would be making it shift hard from park/neutral to reverse/drive, it jerks pretty hard and troubles me that it may be going out or hurting something inside.
Also, My halfshaft U Joints need replacing, and I'm going to do the driveshaft U joints while I'm at it. Can anyone tell me what size they are?
cctroupe09 is offline
Old 06-13-2011, 07:04 PM   #2
toobroketoretire's Avatar
Your idle speed should be around 550 rpm in DRIVE or about 750 rpm in PARK. If it's much higher than that it will make a pretty good clunk when you put it in gear. Your parts store should be able to look up the correct u-joints if you tell them what engine size you have. The big 454's and TH400's use one size larger than the 350's and TH350's use. And I only buy Spicer u-joints with the grease zerks.
Old 06-14-2011, 08:27 AM   #3
cctroupe09
My D idle is 550 and P idle is 700, so it's not that it's idling too high, it still jerks pretty hard, usually when the car is cold and has been sitting.
Any opinions?
cctroupe09 is offline   Send a Private Message Reply With Quote
Old 06-14-2011, 05:19 PM   #4
bluedawg357
bluedawg357's Avatar
Default re:
Dose it clunk when you put it into reverse from park or drive from nuetral? if so it could be a ujoint getting slopy. could also be the differential bushing wearing out.
bluedawg357 is offline   Send a Private Message Reply With Quote
Old 06-16-2011, 07:22 AM   #5
cctroupe09
Yes, when I shift into R or D, it going into gear with a nice loud clunk and the car moves enough to feel it. I know my U joints are worn, I'll be replacing them soon.
I was just curious about it as I was concerned it may have been a transmission problem or differential problem. (my differential is leaking a bit, I'll have to fix that next).
Old 06-16-2011, 08:48 AM   #6
bluedawg357
if your differientail pinion seal is leaking then the ujoints are probably bad enough that you shouldn't drive it. just food for thought.
All times are GMT -8. The time now is 02:17 AM. Powered by vBulletin® Version 3.8.4
