86 TPI Idles Rough, Surges, and Stalls? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C4 Corvette Forums : C4 Tech & Performance : 86 TPI Idles Rough, Surges, and Stalls?
Old 05-09-2011, 08:22 PM   #1
C4TPI
Smokin 50HP Club
C4TPI's Avatar
Default 86 TPI Idles Rough, Surges, and Stalls?
Hi, Im new to the Forum, this is my second post
I recently bought an 86E TPI and its got an interesting set of issues, especially with idle. Id like some opinions and input to start planning a repair route please. Its got a freshly rebuilt motor and trans, AIR pump delete, EGR is connected directly to the plenum(that right?), some hoses are plugged with blots and screws(dislike), its less than perfect I want to fix and restore it, versus watch it rot away.
On start up, the idle drops to 400/500RPM then goes up to 1200RPM, then the idle lowers to and alternates between 600 and 900 RPM. It never stays constant. Its stalling under a minute after start up, and it will stall once the idle drops if I rev it while its in P. Also stalls sometimes when shifting into gear(from R to D). I tried changing out the fuel pump with a new one, but then it would not start. I changed the plugs and wires but to no avail. Any help would be appreciated! This car has potential and Im more a body man than I mechanic, but I love wrenching and getting dirty so Im not afraid to get into it! Want this C4 to actually look and run smoothly like I believe a Vette should
C4TPI is offline
Old 05-10-2011, 04:14 AM   #2
Seabee 86
Seabee 86's Avatar
Send a message via AIM to Seabee 86
Check your MAF sensor.
"General Malfunction"
Seabee 86 is offline   Send a Private Message Reply With Quote
Old 05-10-2011, 06:15 AM   #3
Hotrod
Hotrod's Avatar
Cool
That was my first thought.
Old 05-10-2011, 06:20 AM   #4
slrvette
slrvette's Avatar
My first thought is not your MAF sensor. Rather than going out and spending even more money on something that may or may not work. Your time would better be spent cleaning up your vac lines.
I'm willing to bet that is where your problem lies.
Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED
388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more
In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes.
May he rest in peace, in our hearts and never forgotten
slrvette is offline   Send a Private Message Reply With Quote
Old 05-10-2011, 10:07 AM   #5
Marv02
Smokin 500HP Club
Marv02's Avatar
Idel Air Control Vavle (IACV).
Also Chech the Pink Wire next to the Fire wall next to the distributor you have look stright down between the firewall and the motor to see it, This wire for the spark Advance or anti knock box on the passside by the Heater fan.
I broke mine during the motor swap the pink wire I also had a IACV go bad on me all these cause the problems you are having after you check for vacume leaks.
383 4 bolt main (10.5 to 1) Balanced, Flat top , pistons LT-4 Hotcam, C C ultra pro magnum steel 1.6 RRA, Trick Flow Heads Super 23 (195 runners) 62cc , SPL runners, Hi Flow intake base, 24# FIC Bosch 3 Injectors, Chipped, Melrose full headers, 3 way Main cat, Borla 11134.
700r4 Trans built, 2500 Stall Lock up Convertor, 307 rearend.
403 H/P @ 5000
498 TQ @ 3000
Marv02 is offline   Send a Private Message Reply With Quote
Old 05-10-2011, 04:53 PM   #6
Seabee 86
Seabee 86's Avatar
I agree with Marv02, an Idle Air Control valve is a possibility.
I would agree with Slvrvette only if the OP's condition got progressively worse. If it just one day started running like garbage, that sounds more like a faulty component, unless of course a vac line got disconnected.
Either way all are good suggestions; be sure to give your car a thorough diagnosis and as was stated by others, don't just throw your money away at what you think is wrong.
Old 05-10-2011, 05:54 PM   #7
C4TPI
Smokin 50HP Club
C4TPI's Avatar
I has a brand new MAF sensor. Ill try cleaning it with MAF Cleaner...
I will replace them and get back to you on that
I try to look for this pink wire after work... Oh, this Corvette has no heater or A/C unit and lines. Have an 85 parts car I will be taking the parts from to install it onto my 86. I will order a new IAC soon. Maybe an EGR valve at the same time?
Corvette had this problem when I purchased it 2 months ago. BUT, it has gotten worse with the addition of stalling after revving, stalling after starting, and stalling twice while I was at stop lights in the city...
C4TPI is offline   Send a Private Message Reply With Quote
Old 05-10-2011, 06:19 PM   #8
Seabee 86
Seabee 86's Avatar
Stalling a lot? Hows your fuel pressure?
Old 05-10-2011, 07:21 PM   #9
C4TPI
Smokin 50HP Club
C4TPI's Avatar
I'll check it with a fuel pressure gauge and report back. It stalled on me twice while I was driving in the city one day shortly after I bought it. Also stalled twice when I shifted from R to D in a parking lot. I inspected my fuel pump and saw debris in the strainer so I tried changing out the fuel pump, but that only led to a no start situation. I had fuel at the injectors, but no fire. Put the old pump back in and it started up with some effort... I was listening to the idle today(it wasn't stalling under a minute after start up anymore), I noticed that when the idle drops, so does the tone of the fuel pump noise. Wrong pump maybe? The plastic connector tip on the wiring harness matched up though...
Edit: Fuel pressure is at 39/40PSI
Old 05-11-2011, 04:14 PM   #10
C4TPI
Smokin 50HP Club
C4TPI's Avatar
This car has an EGR Valve but no EGR Solenoid... Read on Ecklers a faulty/broken EGR solenoid causes rough idle and stalling... Should I look into this is well? I have an EGR sol. from an 85 Corvette if that would work?
Tags
c4 corvette idle bad stall
All times are GMT -8. The time now is 12:37 PM. Powered by vBulletin® Version 3.8.4
