how much hp will stock danna 44 rear end hold? - SmokinVette.com Forums
SmokinVette.com Forums : Corvette Forums : C3 Corvette Forums : C3 Tech & Performance : how much hp will stock danna 44 rear end hold?
Old 12-12-2010, 02:10 PM   #1
Bondomatic
Default how much hp will stock danna 44 rear end hold?
Just bought my first vette and stock will not do. It is an 81 with a auto trans and a turd for a motor. Just built a 396 sb with est. 530 hp new t350 trans comming soon with a 2300-2800 stall. Will be changing gears soon but not sure if it handle it or should i look for a diffrent set up? any info would help? This car will not be just a crusier but not full racer either.
Bondomatic is offline
Old 12-12-2010, 02:28 PM   #2
Originally Posted by Bondomatic View Post
Just bought my first 'Vette and stock will not do. It is an 81 with a auto trans and a turd for a motor. Just built a 396 short block with estimated 530 hp. New TH350 transmission will be coming soon with a 2300-2800 stall speed converter. Will be changing gears soon but not sure if it handle it or should I be looking for a different set up? Any information would help. This car will not be just a cruiser but not full racer either.
The Dana 44ICA will handle about 450-500ft/lbs of torque but it will break if a heavy shock load is applied to it enough times. The weakest part of any rear end is the spider gears and the Dana 44's spider gears are a little smaller than those used in the 8-7/8" earlier rear ends. Corvettes aren't made for drag racing. If you intend to beat on it I suggest you put a 9" Ford rear end in it.
Old 12-12-2010, 02:30 PM   #3
fishslayer143@yahoo.com
It depends..are you gonna run 10 inch slicks and do lots of 1/4 miles? then no. but if you are gonna run street tires and occassionally turn it loose, yes. I ve got a 383/501 HP in my 81,built up 700r4 trans/stall..my Dana 44 is all new and REM coated 3.73 gears. 2years so far, no problem..I don t run slicks, but I have a 6800rpm redline and it lights up tires in 2nd gear.
Old 12-12-2010, 04:32 PM   #4
Bondomatic
Thanks for the info guys i might be alright for a while. suspension is on the next to do list.
Bondomatic is offline   Send a Private Message Reply With Quote
Old 12-14-2010, 12:44 PM   #5
if you should decide on solid axle, check this..http://www.racingjunk.com/category/1...nversion-.html
All times are GMT -8. The time now is 09:41 PM. Powered by vBulletin® Version 3.8.4
