: C4 Corvette Forums
: C4 Scan & Tune
Tuning at Idle
A tip about tuning at idle.
DO NOT TRUST YOUR WIDE BAND. Wide band readings at idle are typically thrown off and can read more rich or lean depending on your cam. The correct way to set the idle is to disconnect the IAC, Tape off or otherwise block the holes in the throttle body that go to the IAC. Set the idle you want using the screw on the throttle body blades to get it close. Make it leaner and leaner until you get an RPM drop. Then make it slightly richer. Remove the tape over the holes on the throttle body and reconnect the IAC That should get you where you need to be. Do not look at your Wide Band as a guide.
Office:201-258-5600 Cell:201-403-3699 www.injectorsplus.com www.facebook.com/InjectorsPlus Custom fuel injectors for any application, marine, ATV, etc Tuning stock and aftermarket ECUs Fuel Pumps----Areomotive and Fuel Labs Lines Fittings ---- Red Horse, Fragola, XRP MARCELLA CUSTOM INTAKES ECU-----Fast, Holley, and Motorvation Intakes Manifolds for LSX, SBC, SBF, BBC Carb to FI conversion kits If it's fuel related and you don't see it, CALL, we can make it. |
#2 |
Just to add and since its happening to me. DO NOT live by these WB02's you put in the car. When street turning go by your BLM's more that that wide band. Look at those just a a general guide.
They are not as accurate as one used on a dyno. Good advice up above
![]() Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED 388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes. May he rest in peace, in our hearts and never forgotten
#3 |
Unless, of course, you don't have a stock ECU....
Then there aren't any BLMs.
#4 |
Before you inform me that I don’t know my whatever from a C4/C5, catch the clam shell hood. The car in fact turns out to be a C4/C5. When the engine was rebuilt the heads were shaved, modified for larger valves, and a roller cam installed. Any EM controls are no longer functioning or there including the catalytic converter. Now that I've put 2,000 miles on it the idle has gone from 1,000 rpm to 1,300 rpm. How should I lower it?
#5 |
Your vette came from the factory with a roller cam!
All times are GMT -8. The time now is 07:06 AM. Powered by vBulletin® Version 3.8.4 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd. |
